Multiplus II Low Battery and missing Dynamic Cut-Off page in assistant
I have a 3 phase ess system with one multiplus II 48/5000 GX and two multiplus II 48/5000, cerbo gx, Pylontech battery. Lately I got a low battery (Multiplus switches to pass-thru) warning on the multiplus but not on the cerbo, SoC is the same as on the cerbo (e.g. 85%). When I cut mains multiplus switches to discharging. When I restart the multiplus everything is working fine again. After some time the issue occurs. Yesterday it did not work, no power, I think it thinks it is completely empty.
I checked cable connections, settings, firmware… everthing fine. But I recognized that the dynamic cut-off page in the ess assistant is missing in the older/without gx multiplus.
Has anybody experienced similar?
Thanks
Sven
I restarted the Cerbo now it’s discharging again and the low battery warning is gone.
The missing cut-off page didn’t appear though.
Only the master (normally L1) has the cut-off settings in the assistant, that’s normal.
I thought so but I didn’t found any documentation, thanks
New Update:
After it was below minimum SoC and got load, inverter switched to pass-thru and never came out of it. Only after I rebooted the cerbo then it switched back to discharging. Anything is weird in the cerbo, maybe some issues with the firmware (v3.66).
I replace the cerbo with a new one and will keep you informed.
Dear SvenW,
I’m seeing very similar behaviour on my 3-phase system after updating to GX v3.66 and Multi firmware 510.
In my case L2 and L3 remain in import / pass-through even though voltages, CTs, Dynamic Cut-Off, Assistants and the Pylontech US3000C BMS are all correct.
The system shows no VE.Bus error, and the behaviour is stable until I remove all Assistants — then everything works normally again.
Once the Assistants are added back, L2/L3 go into import again.
My second installation, with the same hardware and the same Assistant setup, but still running firmware 502, works perfectly — so the issue may be related to the newer firmware or ESS logic, similar to what you described.
I will reconfigure everything from scratch and also check VE.Bus configuration with MK3 next week.
Would be great to hear if you observe the same behaviour on GX 3.66.
Here is link to my post
