Hi, on my MultiPlus-II GX with the latest firmware v3.60, I want to change the name (SSID) of the built-in WiFi Access Point. In the settings under Settings -> WiFi -> Access Point, I only see the option to enable or disable it (‘Create: Yes/No’). There are no fields to change the SSID or password. Is this a known limitation of the integrated GX hardware compared to a Cerbo GX, or am I missing something?
As far as i know, there has never been an option to rename the access point.
i am new and i was told that you can perform such settings on the stand alone gx module.
Yeah. I have never seen the option (i have a cerbo, ccgx and and ekrano) and it is a requested feature.
