I am replacing the charging side of an old Solax SU3700E, and retaining the PV side so nothing fancy. The configuration is as follows:-
o AC-IN connects through a two pole rotary isolator to an MCB in the consumer Unit.
o Current transformer connected MP II
o Existing 3.7kw solar connected to CU via an isolator and separate MCB (AC-IN side)
o AC-OUT 1 not connected
o AC-OUT 2 not connected
o 5 x Pylonntech batteries will be connected once settings have been made in the MP II
o It is my intention to set the AC-IN limit at 20amp
So there will be no passthrough from AC-In to either AC-OUT1 or AC-OUT2, the input to MPII is cabled on 4mm2 singles (39amp cable).
As there is no passthrough it would be possible to use a 25A MCB, however would it be better to fit a 32amp MCB, and should this be a Type B, or a Type C due to the potential inrush current.
Clarification would be a great help.
Steve W
