Multiplus II doesn't read configured AC out voltage
Hi all,
I want to set the output of a Multi II to 220V for a number of reasons, but it keeps the voltage the same as the AC-IN voltage coming from the grid (238-247V).
I restarted it number of times - the same situation and the settings are as I set them: 220V.
Any advise here? Am I missing to set any other option, except the “output voltage” option?
The inverter synchronises to grid. So when connected to grid it will be at grid voltage.
It is not an AVR.
If you switch to inverting you should see 220v.
Great answer, thank you!
