I noticed that the charging profile has a float voltage of 13.2V.
That is too low for Lithium Batteries and should be 13.6V.
Is this programmable or is there a way to change to a 2 stage lithium profile?
Sort of depends on the manufacturer requirements. There are many schools of thought on it.
Yes there is a way to customise then voltages.
You can edit pretty much all the parameters.
Are you using victron connect or ve config?
I’m not using anything yet. Still in the investigative phase.
Ok. Well if you do decide to hit buy. Also get an mk3 to usb adapter to updates and program the MP2 inverter.
