I have a new Multiplus 12/1200/50-120V installed in a camper van.
LiFePo4 batteries and a BMV-712-Smart monitor.
The only settings changes to the Multiplus were to set the batty type with the switches.
When the batteries are discharged, they charge fine.
The monitor shows about 14.3 volts when fully charged and the monitor shows 100%.
We checked the monitor last night and it was 90% and is 86% this morning.
There is a small 1 or 3 amp load from lights, fan, etc.
Voltage is 13.8 volts.
At some point it should start charging again, correct?
Anyone know what that would be?
Are there adjustments to the charger settings that will keep this closer to 100% charged when plugged in to 120v shorepower?
