MultiPlus-II AC Connections
I’m working on installing a MultiPlus-II 2X120 in my RV. The MultiPlus-II manual lists the wire stripping length as 18mm, no problem, but it also lists a 18mm ferrule pin for the wire end. Is the ferrule a holdover from the older models with screw connections or are ferrules required for the new spring connections as well?
What ferrules did you end up using? Did you use 10awg wire?
