Multiplus II 48/3000 GX parrarel connection
Back in 2021, Victron sent me a Cerbo GX due to a known issue with the internal GX card of the Multiplus II GX. I disconnected the internal card and have been happily using the Cerbo GX ever since.
Now, I’d like to connect a second unit in parallel to increase the power output on a single phase. My question is: do I need to purchase another Multiplus II 48/3000 GX, or can I use the standard Multiplus II 48/3000 (PMP482305010) without the built-in GX?
Thanks in advance.
Yes you can use a regular multiplus 2, parallel can be difficult to set up and get running good
units manufacturing date/hw version should not be too far apart
Your local official victron dealer can help you with that
