Multiplus II parallel support
Current I own a MultiPlus-II 2X Pure Sine Wave Inverter. Does the 2X version also support parallel operation?
Do you mean Multiplus II GX? Yes, but the second unit should be without a GX device or it should be disconnected. Pay attention to matching units, which is worth reading up on if you do a search in the forum or create a free Victron professional account where you can follow the training.
The original unit is not a gx but I do have a cerbo gx unit. The multiplus is a 120 x 2 which is why I am asking.
The units must match and have same feature set. Probably they will work but unsupported scenario I guess.
Yes, you can use the Quattro/MultiPlus-II xx/3000/2x-120 in parallel.
