Is it possible to connect a Multiplus-II 3000W 230V with a 100Ah Leoch Lithium battery without using any GX devices? If a GX device is necessary for battery monitoring and communication with the Multiplus, what is the minimum GX device required for a system with just one 100Ah battery
solartechuk
(Kadhum )
1
DuivertNL
(Marc)
2
If the battery has a proper bms you could do without, but i wouldnt recommend ist
Easiest is a multiplus 2 GX version of the mp 2 3k
Related topics
| Topic | Replies | Views | Activity | |
| Kommunikation zwischen Multiplus II GX und fremdem Akku | 19 | 721 | 1 December 2025 | |
| Running multiplus 2 with no batteries | 37 | 2069 | 4 November 2025 | |
| Bluetooth for a MULTIPLUS 12/1600-70 16 230V VE.BUS | 0 | 78 | 7 April 2025 | |
| Building an ESS with Multiplus 48, a venus GX and a LiIon Battery | 19 | 268 | 15 February 2026 | |
| Multiplus II GX 48-3000 -nach Konfiguration nicht mehr erreichbar | 20 | 760 | 1 May 2025 |
