Notice this only has one AC-IN, not two as described in the manual. Am I missing something here, or is there a different way to connect two AC inputs to this device?
Well, you’d think that’s true, because that’s what I thought initially… But I got the product (ordered Multiplus-II 2x 120v), and received it. The label on the inside-right side of the panel clearly states it is a Multiplus-II 2x 120v, and is identical to that photo…
Edit: Sorry, I thought you meant the photo of the device… But the screenshot from the manual is from the manual for the Multiplus-II 2x 120V, which is what I have. If that’s the Quattro, it’s possible they just used the same manual for both models, as indicated by the filename. Unfortunately, I’m not able to find the spec for the multi in that manual since there are some clear differences.
The Quattro-II 3kVA units are virtually identical to the MultiPlus-II units except for the additional AC input, so looks like in this case the manual for the MultiPlus-II and Quattro-II just mistakenly shows the connection block from the Quattro-II without denoting that it’s specific to the Quattro-II. I’ll raise this to the documentation team to get that clarified in the manual.
