Hi all. Very new to Victron but I do have an Electrical Engineering Tech background, but still learning heaps. (I’m Retired). I have set up a home system that turns on & off at designated times of the day depending on seasons & weather conditions.
Running the above unit with only a 1KW battery & 1 KW of Solar. Also mostly run on Solar. Therefore very small system so, I like to turn on & off the inverter & switch back to mains power after the sun has gone down so as to negate overnight power drain on the batteries from the inverter. Also don’t see the point of running the inverter feeding nothing for 10-14hrs. I do this by going into the device screen on my PC & swich from ‘on’ to ‘charger only’. Ideally it would be great if in the device screen there was a daily ‘time on’ ‘time off’ automated switching for the inverter. Don’t suppose anyone knows a better way to do this or could we ask Victron to add this functionality to a later version. Thankyou to anyone that can help. Cheers Greg.
