Please advise :- Can a Multiplus II 3K 48V Charger/Inverter connected to Shore Mains / 48V Battery and a 150/45 MPPT,
when the batteries are charged auto switch on the inverter to run off the battery / solar power until the batteries require recharging then switch back to Mains?
if so how would it need to be programmed?>
The answer will depend on whether you have a GX or not.
But you can do something with AC Input control.
The other option for use on a boat is solar wind priority
If you have a GX there are more options if you want to dig into node red a bit more.
Thank you for your fast reply. By GX do you mean a Cerbo GX? As I do have one.
Ok well ac input control works on voltage so SOC switching can be a bit tricky there.
Have you heard of node red and venus os large?
Reading up on them now…Many thanks
There is a quick to set up one that uses the generator controls on the GX if you aren’t already using it to start a generator
gen for ac ignore.zip (911 Bytes)
@MotoringMariah that is quite the panel.
You will need to set your gen start stop on the gx to drive relay 1.
Program your parameters on the GX.
Import the above after unzipping. Adjust as the code by double clicking the node for the inverter as will be looking for my inverter still. There is a note there.
Summary
Deploy.
Test.
I had something else in mind but this seems simpler as you va basically ‘edit’ the code using the gx gui as you like. And have …
