The Multiplus is installed in the caravan under the bed and doesn’t breath to well. I want to install a Noctua fan with PWM so I can turn the speed down. Is there a 12V supply I can tap into to turn the fan on, or use the PWM capability when the inverter is in use, heavy use? Thanks
Related topics
Topic | Replies | Views | Activity | |
Pwm temperature controlled External fan | 7 | 49 | 18 June 2025 | |
Multi Plus 12/3000/120-50 120 VE | 0 | 19 | 25 May 2025 | |
MultiPlus II 12v 120V mounting postion | 2 | 88 | 4 March 2025 | |
Multiplus | Maximum power without engaging the fan | 3 | 302 | 6 November 2024 | |
Multiplus ii fan noise | 5 | 210 | 19 May 2025 |
