Multiplus GX Starting without Internet and external Grid
Hello.
Does anyone know how I can start the Multiplus GX if it has previously been switched off via the VRM portal and I have no internet (WLAN).
This can happen if there is a power outage on the external grid.
I just need the emergency power output active.
Does this perhaps work with the Victron Digital Multicontrol Panel?
Thanks!
Are you looking for a local switch on?
It can be done on the GX itself.
Device list - inverter - switch state.
Hi, I have found this:
Geräteliste/Multiplus/Umschalter/ (AUS/Nur Ladegerät/Nur Wechselrichter/Ein)
Is this the function for the 3 position switch below the housing?
But it doesn’t help me if I don’t have internet and the soft switch is set to off
Grüße, Andreas
If you software switched it off over the vrm, it has to be turned on using the GX Menu.
You can connect directly to the GX hotspot and use the remote console.
Something similar to how it is done on a cerbo GX.
If you disconnect the GX while trying to power it, it might help, or not :slight_smile:
(slightly harder to do on a built-in GX model)
