According to the datasheet (https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-500-1200VA-120V-DE.pdf), the Multiplus uses the G-ST18i System for the 230V lines.
According to the manufacturer Wieland, it is not allowed to mix different brands of the connector within one system. The expression “G-ST18i” let’s assume the Wieland system is being used.
However, the victron system uses Adels Contact plugs:
I am wondering which brand of these connectors should be used? Which brand would you recommend?
We need to order cables very soon, so a quick response in either English or German would be appreciated.
Thank you in advance and have a good day,
Florian
