Підключення Victron Energy MultiPlus-II GX та Liontron LX48-100
Hello!
I’m mounting a home system with:
+Victron Energy MultiPlus-II GX 48V 3000VA/35-32
+Liontron LX48-100 battery (supports CAN, RS485, RS232)
Could you help with these questions?
  1. Can I connect them without additional devices (such as Corbo)?
  2. What type of cable do I need?
  3. What connectors on the Victron and Liontron should I use for this?
hi @Mitetim
Yes you don’t need Cerbo GX since your Multiplus II GX has it built in.
Just classic RJ45 cable, preferably CAT6 or 7.
Simply the VE.CAN port; to simplify your research, your battery is almost identical (connection level) to the Pylontech battery
@youn , thankfully! Will try.
@youn , do you know what is the sign of ve.can at the devices? Victron has bms-can and ve.bus, Liontron - Can, RS485.
Yes you have to use the BMS.CAN port; I’ll give you a link to the documentation for the pylontech; normally the principle is the same.
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
