Multiplus current limit from shunt?
Is it possible to limit the multiplus charge current with shunt pairing so that it charges the battery at maximum 30 amps but compensates the load so it increases limit until that 30 a is reached?
So this is not possible?
Are you using a GX device like a cerbo?
Currently no. I don’t also have the multiplus yet as I’m checking the options and this adjusting charging is one I want to achieve in the end. Is it possible with cerbo?
I believe that you can set a maximum charge current limit using the Cerbo GX. All devices connected to the Cerbo GX (solar charge controller, Multiplus, etc) would follow that limit. I could be wrong but I think this is available with the DVCC feature.
How would you set this up with Cerbo?
Using DVCC, see the cerbo manual.
