Help!! Just they other day the leds start flashing from the ve bus control and on the multiplus compact.
Everything works fine butt the flashing is very annoing.
Download the Victron Toolkit app on your smartphone and then enter the lights that are flashing and you can determine what the code means from that.
Ok i did install the toolkit. Combination onknow, it says.
Strange thing is it is working fine, but those annoing led its driving me nuts.
The Flashing LED’s is a way of identifying a unit during configuration phase, and is not normally seen during normal use. You may be able to turn this off with inverter settings in Victron connect, but you can certainly do this using a Mk3 adapter and VE configure running on a laptop.
Hi @Martin3
Could you please record a short video of the LED pattern and I can add it to the Victron Toolkit app.
Yes i can. Thank you.
That looks like the standard “flash leds to identify” signal.
