Multiplus + Basengreen Parameters
Hello
I ordered an Basengreen battery 300Ah and want to connect this to my Victron multiplus 2.
When I look at the internet I can’t find any parameters to config the Victron, has anyone the correct parameter to program the Victron please?
If this is your battery, then the BMS won’t communicate with either the Multiplus or a Cerbo.
See Battery Compatibility [Victron Energy].
For voltage settings, you should have received some data from the manufacturer, or this will be printed on the battery itself. These limits can be programmed into the Multiplus.
Hello
When i read the documentation there is support for Victron, the BMS talks CAN on 500Kbits.
Only i can’t find any voltage and current.
I orderd this battery: https://www.basengreen.com/product/eu-stock-51-2v-300ah-15kwh-wall-mounted-lifepo4-battery-pack-lifepo4-for-solar-energy-storage/
Yeah, there is not much to go on. It may be best to contact them directly.
A few thoughts though.
It is 51.2v nominal so a 16s battery likely.
2.5v cut off (16x2.5 = 40v). I would set the system higher though.
3.65v max cell voltage (3.65 x 16 = 58.4v) seems crazy high for eve cells. So i would set the charged voltage possibly closer to 56.2v
Float at 55v.
That would be similar to those who have similar ranges in their cell management.
In keeping with many eve cells 100ah is 100A discharge so 300 may be 300A? Again the bms could be less capable who knows? (Hint: basengreen themselves)
When you get the comms working, have a look then what it is sending to the system.
Does their app not tell you anything?
Did you find already the right settings?
I am have also some problems.
Maybe you can share your settings?
Hello
Sorry for the delay.
I have settings, at least in think, i send an mail to BasenGreen to verify, after i get the approvement can send it to you.
Or did you solve your problem already?
What do you prefer as Absorption Voltage?
