does anybody know why I have a constant red bar? The system is on a boat with Lynx BMS NG. The inverter load is nothing. No error or BMS messages.
Thanks Norbert
I think it just indicates discharging from the battery.
As per Justin’s comment, bar represents load. The scale is auto ranging, so if you have never had much load say only 100W max then 100W becomes the max range so when you are say over 90W it goes red. In the Display Settings you can swap from auto range to manually inputting values.
Thanks. Till now I’ve never been to that menu item before.
