Multiplus 2 low battery alarm with jkbms (Configure victron and jk-bms voltages)
So when I take the worst value, of 1 volt drop at 88 amps, I get the following result:
0,005C = 0,0178V drop
0,25 = 0,8920V drop
0,7C = 2,4977V drop
2C = 7,1363V drop
The idle voltage of a cell at 10% is 3 volts and at 10% it is 2,5 volts. So I’ll take in between 2,75 volts as minimum voltage (+/- 5%) which is 44 volts for the battery so it never depletes to 0%.
This gives me the following numbers:
0,005C = 44,98V
0,25C = 44,10V
0,7C = 42,50V
2C = 37,86V
Am I in the good direction?
I will also measure voltage drop at 50% SOC later.
