Buonasera,
ho appena acquistato un MP2 24/3000/70 vorrei sapere se per poter utilizzare la funzione power assist ho necessariamente bisogno di acquistare anche il sensore di corrente opzionale (50A per la versione 3000VA).
GRAZIE a tutti
I believe the external AC current sensor is needed only for when you want to feed-in or not. Otherwise, no.
Look below from the brochure.
Thank you!
so it is not necessary if it is necessary to limit the input current to the mp2? what is the minimum value that can be set at the input?
If you take a look at the MP2 manual, at page 34, it shows that there is an internal current sensor on AC-IN for exactly that.
I believe that the lowest value is 1A, but I may be wrong as I don’t have an MP2. Take a look on the configuration software.
