Multiplus 2 drains battery when DESS target soc = soc with 118 watt in idle discharge mode
So I got a current clamp and the victron is drawing 0,3 amps, so the jkbms is completely wrong with measuring 1,8 amps.
I will send JK an email but I really doubt they are going to solve this.
I now use the measurement of the victron to calculate the soc which works fine.
A well-known and much discussed problem. Soc calculations about BMS are crap
It isn’t even the calculation, the current measurement at low currents is completely wrong causing a soc drift.
A friend of my has the same jk bms and his bms doesn’t have this wrong current measurement.
Let’s see if JK will give support or an exchange on this faulty bms.
Your BMS is not broken. This is a general problem whether it is a JK or another manufacturer. But feel free to try it.
I now discovered (again?) that in inverting mode the jk shows the correct current. Maybe a ripple of the victron when conneced to grid is causing the jkbms current error?
I will connect an oscilloscoop to the 48 volt bus later on to see if I can see any ripple or distortion.
There’s an old man on YouTube who can tell you a lot of wise things about the JKbms “the offgrid garage” he tells you, you can calibrate the current in the app. High currents are pretty accurate to but below 2A you know you got a cheap Chinese thing. You got what you paid for!
installeer een Smart Shunt zoals de ouwe man heeft gedaan
The multiplus battery monitor is precise enough for me, I just ignore the jkbms.
But I still wonder why in inverting mode the current is accurate below 2A and when conneced to grid it isn’t.
Still have to hook up my oscilloscope to see the difference.
It’s peak shaving which cannot be disabled which drains the battery. When peak shaving stops at minimum soc the ghost discharge current dissappears.
Still there is no option to disable peak shaving.
