I’ve now spent many many hours trying to figure this out. I have two Multiplus 2s set up in parallel to provide split phase 240 volt. I’m using a double pull 30amp breaker to supply the AC In to both Multis- 1 leg going to each Multi. It’s showing that it has 120v AC Input at the Multis but on the VictronConnect App it shows the AC1 Input line up and not supply power in and also stats on the right that AC Input is ignored.
I have charger enabled. When I changed it to charger only, it shuts down both Multis.
This is being run at a cabin. I have a solar system charging the multis but in the winter, I’m not going to get enough sun, so I want to be able to charge my batteries and run off AC pass though power to run a heater in my garage when needed. I’m running all Victron equipment-150/45 MPPT, SmartShunt, Cerbo GX.
Everything else is running fine… just cannot figure this out. I will eventually put in some assistance so it knows to use AC Input power when the AC load is over 1500watts or so or start charging when the battery gets down to 70% but for the life of me, I cannot figure out why the system won’t use the AC Input power that’s already plumbed into the Multi.
Any help is very very much appreciated!
Thanks,
Kyle
