Multiplus 1 low voltage output
vectron multiplus 1 putting out low voltage output. can anyone help?
I am using a multiplus 1 24v/3000w/220v inverter charger connected to 8 250w panels, with 4 Rolls S6 L16-HC batteries connected in series parallel to give 24v. The inverter is connected a Victron auto transformer to step down the voltage to 110v however when i do a volts test from l1 out of the inverter i am only getting 160v going to the transfer switch. have anyone encounter this problem before, and if so. How was it resolved?
Please add more details about your system and the problem.
