I am considering having two Multiplus 12/3000/120 units installed, but not operating in a parallel or split phase configuration, but rather just independently, each supporting individual AC loads, but drawing from and charging the same battery bank.
If I set it up this way, can I have 2 digital multi controls with each one only associated with a single Multiplus? Both Multiplus units will be on the same network, connected to the same Cerbo, etc. They will share the same DVCC source. How will the battery charging work? Will the Multiplus units communicate in a way so as to synchronize charging parameters?
