Multi Rs Solar 48/6000 /100 MPPT 450/80
It is the first time I discovered it. I normally don’t need the storage voltage setup, because of the house installation and continuous discharge and charge. The Inverter stuck in the Storage Voltage mode, even the Sun is out to charge the batteries. How to reset, and bring the inverter back to bulk charging without switching off the Inverter and darken the whole house? Can this function switched off, maybe?
Hi there,providing You have got a decent bank of batteries,the storage is quite a nice extra:it avoids having Your LiFePO4 unnecessarily sitting on float.Set the storage to float settings to avoid dropping lower than float.It should jump in after about 10 min. or latest next charging cycle,without having to switch the inverter off .Cheers Frank
Thanks, I’ll try.
