As the manual says, it is for a 48 Volt batteries system, max charging voltage is 62 Volt. I have my batteries bank upgraded from 16s to 17s. The maximal charging Voltage is now 3.647 VDC per cell, which is definitely safe for the cells. So, the Inverter can cope with 17s easily, even it is concepted for 16s /48 Volt, right? I have set the absorption voltage to 59.50 Volt, 2.5 Volt below the Maximum. It should not harm the Inverter over time, right?
Depends on the quality of the components used inside.
For example, all RSes that I’ve seen are using 63V rated capacitors on the battery side.
They say that the max charge voltage is 62V… So one can do the math…
As those capacitors are functioning with high ripple currents, In my opinion, is too close to the capacitors voltage limit for comfort…
So, all Victron Inverter is for 48 Volt. Any suggestion which Inverter + MPPT I can use instead?
With 17S you are within the range that is possible with every 48V Victron device.
Problems start with 18S or other battery types that go even higher.
You are relatively safe with the 62V, again, depending on the quality of materials.
In contrast with Multiplus range where they need to use a lower and variable high frequency PWM for generating the 50Hz sine wave, in RS range they use a relatively constant higher high frequency for the DC/DC converter that converts 48VDC to 400VDC.
So the ripple current on the RS range is a milder one than on the Multiplus range, so maybe this was a reason for using 63V rated capacitors, beside, probably, the cost, because the space was not, for sure, a constraint.
Okay, thanks guys. It seems, if the inverter is not continuously on its charging limit of 100 Amps, the system is stable. It is in use now for around 10 months. I was just curious if there is someone with a similar configuration. The fact, LFP batteries are charged to 3.45 Volt (58.65) only, makes it possible to max out this Inverter up to 17s. Just in the winter time with less sun, the reserve to switch in higher charging voltage is lower.
