MPPT settings for GEL battery
Hi there,
What settings should be configured on an MPPT 100/50 for working with the following GEL battery?
12V 300AH C100 ELEKSOL GEL battery
Constant voltage charge
Cycle use: 14.4 - 14.7V
Standby use: 13.5 - 13.8V
Thank you
Manufacturer specific setting can be configured under custom settings and will depend how the battery will be used. If you discharge and charge daily, the use the cycle use as per the Eleksol instructions. Otherwise, use the standby use settings.
Thank you. Finally I realized my battery specs are exactly the same as the Victron Gel Deep Cycle, so I used the preset for that one.
