Mppt 75/15 battery selection for agm deep cycle
Hi, cant find a battery selection in app (victron mppt 75/15) for my new “victron agm deep cycle batt” 12v 220ah, PN: bat412201085, SN: HQ2452H2Y7C. Only AGM default is “AGM spiral cell”… Thanks for any help!
Table three in the datasheet
Preset AGM spiral cell fits, a bit on the high end, but you can adjust the voltages manually
Thanks for the quick reply! One additional question, according to (from pdf): “Research has shown that battery life can be increased by decreasing float voltage to an even lower level when the battery is not in use.” My battery is only used on 30 days per year, so most of the time battery is totally full. The last AGM only lasted for 3 years…. Is it possible, that high float voltage is the reason for the breakdown? Thanks for any help!
