MPPT RS450/200 power limit
Hi @ all
I have a MPPT RS 450/200 in my victron system (3xQuattroIIw 5000 48V + CerboGX).
Is there a way to limit the output power of the device? I read it maxes to about 12kW, which currently is more my system can take. I want to limit it to 4kW for now.
Thanks
You could try limiting the Charging current via ‘DVCC’ here
Doesn’t that only affect the battery?
I mean its usually full in summer during the day so charging should be a zero. Seems that limiting the MPPT is an odd request…
In the settings (via VictronConnect) of the MPPT you can limit the current.
But I’m not sure what your problem is.
It doesn’t work, I’m having the same problem.
