I read the rs450 has 3 x 4kW max and 11.5kW total max
but maybe you will hit that 11.5kW across 4 strings if you had 3kW on each
cause mine maxes out at 10.7kW. 2 of the strings reach peach 4kW and 3rd string is 3.3kW. it’s not a panel problem cause the charger alternates from time to time which of the strings to reduce by 700W
so not sure if that’s normal or bad setting or needs update
