MPPT RS 450/100 goes into limiting despite DC-coupled PV — feed-in excess
Hello everyone, this is my first post here in the community. I hope you can help me. Now in English, hopefully to receive some feedback.
I’ve been observing this behaviour for a few weeks now. During the summer, the MPPT always fed in at full power without any limiting.
Back then, DVCC was active and CCL set to 0A in order to charge only via DC.
Now in winter, I want to charge using both AC and DC surplus, and CCL is set to 70A–100A.
System description:
  • Operating time: approx. 2 years
  • 1 × VM-3P75CT
  • 3 × MP2 5000 – 3-phase FW: v508
  • Venus OS V3.66
  • 1 × MPPT RS 450/100 FW: v1.26
  • Networked: YES
  • Network status: Slave
  • Mode setting: Ext. Control & BMS
  • BMS controlled: YES
  • ESS configured
  • Grid feed-in, DC-coupled PV – feed in excess: ON
  • DVCC: ON
  • CCL: 70–100A
  • CVL: variable between 54.4V & 55.2V
Normal operation:
MPPT charge voltage: CVL + 0.4V
Undesired operation:
Limiting occurs without any visible reason. The first reduction of the day usually happens when
MPPT charge voltage = CVL at charge currents >50A, but sometimes also with a bit more or less.
At that moment, all energy is still going into the battery.
Battery voltage: 52V–54V (below CVL)
MPPT charge voltage: CVL (the +0.4V is missing) !!
MPPT charge current: varies between 50A and 80A
Shortly before the battery is full, the MPPT RS 450/100 goes into limiting when MPPT charge voltage only equals CVL.
Actually, the +0.4V should always be present to enable surplus feed-in.
Once the battery is full, MPPT charge voltage is consistently CVL + 0.4V, and full feed-in works again.
Overnight, no jumps in MPPT charge voltage can be observed. During the night it is always MPPT charge voltage: CVL + 0.4V.
What could be causing these jumps in MPPT charge voltage?
Why are the +0.4V sometimes active and sometimes not?
deutsch:
Hallo zusammen, dies ist mein erster Eintrag hier in der Community. Ich hoffe ihr könnt mir weiterhelfen.
Das Verhalten beobachte ich seit einigen Wochen. Im Sommer wurde immer voll eingespeist ohne Begrenzung.
Damals war DVCC aktiv und CCL auf 0A gesetzt um nur DC zu laden.
Jetzt im Winter möchte ich über AC- und DC-Überschuss laden und CCL ist auf 70A - 100A eingestellt.
Systembeschreibung:
Laufzeit ca. 2 Jahre
1 x VM-3P75CT
3 x MP2 5000 - 3Phasen FW:v508
Venus OS V3.66
1 x MPPT RS 450/100 FW:v1.26
Networked: YES
Mode stetting: Ext. Control & BMS
BMS controlled: YES
ESS konfiguriert
Grid feed-in, DC-coupled PV - feed in excess: EIN
DVCC: EIN
CCL: 70 - 100A
CVL: variabel zwischen 54.4V & 55.2V
Normalbetrieb:
MPPT Charge voltage: CVL + 0.4V
Nicht gewünschter Betrieb:
Begrenzung ohne sichtbaren Grund, meist tritt die erste Reduzierung am Tag von
MPPT Charge voltage: CVL bei Ladestömen >50A auf. Aber manchmal auch bei etwas mehr oder weniger.
Zu diesem Zeitpunkt geht die ganze Energie noch in den Akku.
Batterie Spannung 52V - 54V ( unter CVL)
MPPT Charge voltage: CVL ( die +0.4V fehlen) !!
MPPT Charge current: unterschiedlich zwischen 50A bis 80A
Kurz bevor der Akku voll ist, geht der MPPT RS 450/100 in die Begrenzung wenn MPPT Charge voltage nur CVL entspricht.
Eigentlich sollten immer die +0,4V vorhanden sein um die Überschusseinspeisung zu ermöglichen.
Ist der Akku dann voll, ist dauerhaft MPPT Charge voltage: CVL + 0.4V und somit wird dann auch wieder voll eingespeist.
Über Nacht sind keine Sprünge bei MPPT Charge voltage festzustellen. Hier ist immer MPPT Charge voltage: CVL + 0.4V
Woran können diese Sprünge der MPPT Charge voltage liegen?
Warum sind die +0.4V mal aktiv und mal nicht?
Hi to all. Is there no one who can help me?
