@lxonline
Just keep in mind that at lower light level the 450/100 will start up later than the 250/70 and probably shut down sooner because of the start stop voltages.
Valid point…
Although you can’t beat this ability. Unless you get 2 smaller controllers which then adds wiring and bit of complexity i guess.
Yeah, only had the RS “in my basket”, didn’t apply “buy & deliver” yet… Need to do some more calculations for my final decision, at least I know I have two options now. One device is simpler indeed, but if I need the extra wires, well… But it’s also another Lynx, because with 3x MP 4k5 and two MPPT’s I’m missing a port to connect the second MPPT at my busbar
. I do have a single port available at the other Lynx (T-Class) where my battery is, but I don’t think my MPPT should be connected there. Well enough to think (and worry) about, still, but thanks again!
@kr0815
What do you want to do with the harvested PV Energy? Store it in a Battery or consume most of it directly / feed it in the Net?
I already have a 2x 5 Panel 3kW AC (Enphase) setup at 130° (the other side of the roof). The MPPT’s are going to (help) charge the batteries and/or feed the in-house AC demand if needed (with the help of three MP 4k5’s for the DC/AC conversion). From 2027 it doesn’t make much sense to feed back to the net in 99% of the use-cases in the Netherlands, because you will get charged seriously for that.
I’m not going to bother you with all the stupidity of the Enphase software eco-system. Let’s just say I’m loving their Micro Inverter technology (really, they are a great piece of engineering), but everything else is amateuristic or blunt stupid… But let me skip to your next question:
I ask because i wonder - i don´t se much sense in DC MPPT Converters for ESS Systems
In my humble opinion MPPT’s are fabulous in ESS Systems, because you directly charge your DC batteries with DC current. As my Enphase system connects to the AC-Out-1 of the MP 4k5’s, they will cover the home AC loads first and charge the batteries second with any excess power.
Be aware that the source of the AC power from the Enphase system started as DC (converted to AC by each Micro Inverter), so charging my DC batteries from that source will get another AC/DC conversion for battery storage and again a DC/AC conversion when consumed. I’m not a native speaker, but I believe the saying is “Third time’s a charm…”, well, that isn’t true for power conversion
Another thing is controlling the charge loads with 100% SoC. When connected to the grid the Enphase will feed back in to the net, which will cost me money (see above), when off-grid the MP 4k5’s (because they are in charge of the main power now) are capable to “frequency shift” the AC feed by manipulating (slightly ramp up) the standard 50Hz AC frequency. That will work for limiting the AC inverter, but it has all kind of side effects I don’t want. The simplest example would be that your digital clocks will be a bit faster than normal
, but I have some other concerns/workloads for not wanting that type of PV Inverter throttling.
Did I already mentioned the stupidity of the Enphase software eco-system
? Now they do provide a ModBus connection for throttling with their local monitoring device (Enphase Envoy), but mine is not capable at doing that (simple version). I don’t have the required firmware (on-purpose) and even than you need a “special” support request hoping someone will respond and allows (sigh) you to use that functionality.
But back to the MPPT’s, these devices can be throttled/managed by your GX and if my Enphase covers my house load and/or the battery charge demands, the MPPT’s are dismissed for a while :). If in any situation my batteries are loaded, the MPPT’s are shut off and I still have excess PV power, I’m going to start a anti-salmonella run with my heat pump or just heat the water in the boiler towards 70°C
. But that scenario would be a real outlier, my Solar Power is quite balanced for my house loads + ESS.
TL;DR
In my humble opinion MPPT’s are fabulous in ESS Systems…
