They don’t usually get fixed if it is product fault. They get replaced. More often than not the FETs take a hit. And repair is not as reliable as replace.
Overvoltage on the PV side or overamped (too many panels in parallel) or loose connections causing other issues. Ao a configuration issue.
Possibly a fault from the battery side can cause an overshoot (and on an mppt being oushed to the edge of it’s tolerance) and the device has to absorb the overshoot something will give.
