MPPT Control
I have a victron charger and lifepo4 batteries. I bought a monitor to show me what the charge, Pv etc. is. It’s been workoing perfectly. Tonight, I had to move the display and unplugged the cables (the VE Direct and the power from the batteries). It’s dark - I prefer to do anything like this when there’s no PV power - and now when I have plugged the cables back into the monitor, it simply scrolls with DISCONNECTED. None of the buttons seem to function.
Is this because the controller is now off, which means that when the sun comes up all will be good? Or have I done something else inadvertently? The controller won’t reset to default values, will it? I have my system to be bulk up to 28.8, absorb up to 29 for float.
Hi Nigel,
It s possible with older MPPTs that do not stay powered when there is no PV that it indeed shows disconnected while it has not seen the MPPT.
Is it still showing DISCONNECTED?
With kind regards,
Thiemo van Engelen
