Hi, on my 75/10 MPPT there’s no option for flooded lead acid, only AGM and Gel. Only ever run small 096 batteries on my boat. got calcium ones on at the moment if that makes a difference. What should my settings be ? Cheers
The advice is to check your battery supplier / manufacturer settings.
Related topics
| Topic | Replies | Views | Activity | |
| MPPT 250/100 Rotary switch - which number for lead acid? | 6 | 141 | 27 December 2025 | |
| Which preset on an MPPT 75/15 | 1 | 126 | 13 June 2025 | |
| Looking for advice for flooded lead acid battery setup | 1 | 375 | 23 August 2025 | |
| Benötige Hilfe bei der Einstellung das mppt 75 10 | 0 | 62 | 5 April 2025 | |
| AC/DC and solar -> MPPT to lead acid / LiFePO4 battery | 4 | 255 | 6 October 2025 |
