MPPT Calculator tracker copy button
It would be nice if the MPPT calculator would have the ability to copy a tracker, or at least a custom module into a new tracker.
So for example, you typed in some custom panel specs since the panel is not in the database.
In order to use that same panel now on a second tracker, you then need to type in the data again. And so forth for as many trackers you need.
Something like this
I had that exact problem and it was a pain in the proverbial something. Imagine you need 4 trackers!
