Current setup in my Land Cruiser is a 100ah LiFePo charged from start battery by a Victron Orion 12|12-18. The battery includes a BMS but no Bluetooth connectivity so I am using the BMV 712 and shunt to manage and monitor amps in/out and SOC of the battery. The monitor has a single RJ12 connector on the back of the gauge.
I am going to add a MPPT 75|10 to the mix and believe the neg output should attach to the shunt and the pos output should connect direct to the battery. Relatively straight forward. How do I get the MPPT to connect to the BMV 712 so I can view parameters and output?
See install thread here
