BMV700 and Bluetooth
I am upgrading my van system with lithium batteries from lead acid.
I have an existing BMV 700 monitor and shunt -
If I buy a ve direct Bluetooth cable, will my existing BMV700 then work similar to a BMV712, so I can set up lithium settings and view via victron app ?
I also have an existing MPPT 75 - 15 without bluetooth and a victron MPPT control display . - Can I use the same cable VE direct to bluetooth cable to set up lithium settings on the MPPT ?
I have also just purchased a 24 -24 -17 tr smart DC DC charger - I assume this will also connect to the same victron app ?
Thanks in advance
