Newly branched mppt 75/15. I can see the voltage from the pannels but no amps.
Any ideas? I’ve tried most everything. Switched the mppt out with an other, works fine.
@tieole
Check the polarity of the panels.
I guess the next thing i would check would be updates and programming.
If that is correct then check the fuse?
Checked the polarity, updated and reset the mppt. The fuse is fine. I switched it out with a 100/20 I had in stock. I’ll contact the distributer.
Yeah you are definitely at that point. How strange.
