MPPT 250/100 PV Input appears shorted. Read the manual about the protective relay, but can’t find the “Product page” using Victron Connect to check error codes or reset the relay. Help
Perhaps I should be clearer… Array has 140V, output is good. When I connect the array output, to the Charge controller output goes to 0. If I put a meter on the PV it reads near 0 ohms. New installation. I believe the shorting relay has been tripped…
I can’t find the “product page” referenced in the manual.
thanks for help helping me find it.
Perfect answer. Thanks! I found it, reset the relay with my bench power supply set to 12.0v, 400ma, but it did not resolve the issue… Augh! Still “Off” no PV.
