Since a couple days my mppt is not charging my battery.
I have a 200ah Lifepo4 connected on a mppt 100/30 with 3 x 200w solarpanels. I have enough voltage on the solar side but current and watt stays at zero.
Any idea what could cause this problem ?
Please can you post your MPPT settings.
possible causes: Incorrect settings - ABS,FLoat voltage set too low.
Blown fuse - MPPT battery voltage different from actual battery voltage
BMS for battery not accepting charge.
Those look ok,
Please can you give a translation of status “Aan”?
If the unit has a load output, what happens if you connect a load? (20 - 40W). Do you see load current? does this come from the battery or from solar?
Measure the battery voltage at the MPPT terminals, and at the battery terminals. This is beginning to look lie a blown fuse / dirty connection somewhere.
It may also be possible that the battery may not be accepting load, but I would then expect to see the indicated voltage equal to the float voltage.
How long has the set up been in place?
If it is a new set up check your pv polarity. It is possibly backwards.
The status “AAN” means ON .
I have measured at the terminals and I measure 16.1v at battery side and 78.9v at the solar side on the solar charge controller
On the battery itself it says 13.3v.
Between the solarcharger and the battery I also have an batteryprotector
No not new been running very good for like a year but only since a couple days it won’t produce
If tou are measuring 16v at the mppt but 13v at the battery then the device in the middle has failed most likely.
It is a good idea, but not essential to have a battery protect between the charger and the battery. However, this can only be omitted IF
IF you are measuring 16V on the output of the MPPT, then the Battery protect may have shut down from overvoltage.
Yes my battery has an internal BMS . I measured again at the terminal of the mppt again now at the battery side and it’s in the 13v again.
Thnx for the help
