Monitoring PV charging excess for use, at cat6 cable end
Hello. Newby here and not too much off a sparky…we have a link to the web to monitor our system. This is via the internet as a cat 6 cable is plugged into our wifi router. This is wired via the walls in the house by a sparky. We have had to move to starlink, the satellite antenna has a cat 6 cable connecting it to our router. The cat 6 cable from the battery/solar setup is inside and plugged into the starlink router as well so we can monitor the setup via the internet app. However the antenna cat 6 cable is then forced to come inside though an open window to the same router. can we put a physical monitor (BMV712 ??) on the battery cat6 and move the router elsewhere so can close the window. This will mean the data is not on the internet but we can physically see it on the monitor.
My question is which monitor? It will need to be POE powered and cat6 data compatible. Any recommendations? Thank you!
The BMV 712 does not have an ethernet port.
What victron equipment are you using?
