Measuring heatpumps and EV-chargers
In changelog for v3.50~9 it is said that VM-3P75CT could be configured to measure heatpumps or EV-chargers.
Why only the new VM-3P75CT? I have a ET340 for my heatpump installed to record the data in VRM and make some node-red flows with it. For my EV-charger I have an EM24ethernet because it’s in the garage far away from my cerbo GX.
@mpvader Do you plan to make ET340 and EM24ethernet usable for heatpump or EV-charger, too?
…in the settings for each Energy Meter, regardless of make/model as long as it is enabled/listed in the GX, you should be able to set it to either role of evcharger or heatpump (besides the older ones, like grid, acload, pv-inverter) - when running 3.50beta.
Did you try that out with your EM340 and EM24?
Yes, I know the setting. I switched the heat pump’s ET340 from AC load to heat pump. A new entry is then created in the device list. Unfortunately, the ET340 is then neither visible in the VRM nor in the dashboard on the GX. I couldn’t try it out with the EM24ethernet for the wallbox because it isn’t fully installed yet.
I know of others, that at least were able to represent a non-victron evcharger that way.
…what happens, when you set the ET340 to role of “evcharger”?..only for a test of course.
Maybe the heatpump feature is not yet fully ready, being introduced in 3.50beta.
Good idea. I tried it and got an EV Charger on my dashboard at VRM.
…so maybe a “bug report” is in order, regarding the use of the heatpump role ?
What happens when you start charging your EV…does the tile reflect the the Power/Energy values from the ET340?
I’ll try this later when I’m at home. I can’t trigger the heatpump remote.
Yes, the evcharger is a heatpump, this time…I forgot :rofl:
So, now the heat pump was running disguised as an EVcharger :wink:
Meter is an ET340.
GUI V1 only visible in the device list. GUI V2 visible on the overview page. VRM only icon visible but no values.
…so, GUIv2 does the trick, at least partly, as it seems.
The “problem” with the heatpump in disguise of the evcharge and the GUI might be caused by the fact, that an evcharger somehow can/needs to be switched on in its settings.
At least the metering values are shown.
As the heatpump role is fairly new and not many users will experiment with it (as victron doesn’t produce them), it is very likely that this is a bug…you should report it to the team.
Tested switching from AC load to Heat pump EM24 Ethernet meter.
When it is AC load - visible in Device List of both gui-v1 and gui-v2
When changed to Heat Pump
Also, when meter is in Heat Pump role it is not listed in VRM(beta) as a device.
I believe this functionality is too early to test.
I’ll wait for Victron team to provide first steps to test.
Hey all; exactly. Some work was done on our side for this - but it is not complete yet.
There will be more info in the changelog while we get closer to having this really usable.
Have a good weekend
Hi, thank you for the info. We are looking forward to testing the functions.
I was checking to see if Victron would have updated Modbus registers for the heat pump and EVCS meters, the AC loads addresses don’t work as soon as I switch the role of the meter.
regards George
In recent updates to venus os and VRM heatpump stats can be visible in Advanced graphs.
No control yet
I am not able to set meter to heatpump role, however it is configured in dbus modbus client.
What do I miss?
Yes for me the same problem, there is no heatpump role for de EM24 only AC-loads…and not to see in de VRM portal.
In the recent beta version still no Heatpump option available for selection + the Position option is broken - cannot select location of the meter.
Would be nice to know, if there is any time frame for this, or is it better to forget all these fancy “features” and keep continue creating my own Grafana dashboard for monitoring separate AC loads? Now “other AC loads” are monitored under “AC load MP 2x3000VA”
Thanks,
Best Regads,
Kimmo
(Replying to the correct author this time)
Hello @mpvader,
Since I noticed upcoming VM-3P75CT features in this thread I’m bumping this thread a bit :slight_smile:
(Also not to pollute the VenusOS Beta topic)
Is there a planning for the VM-3P75CT monitoring heatpumps and/or EV chargers ?
(At the moment I can’t remember if it’s possible to monitor these with another type of energy meter)
