Vrm separate graph for EVCS usage
I have added the EVCS to my system, and i expected in the VRM interface that part of my consumption would be categorized as EVCS usage. would this normally be the case or is this not part of VRM?
I would also like DESS to ignore my car charging consumption in the power estimations used for DESS. How would i achieve that?
screenshot of vrm for reference.
I would expect that the usage between 1:00 and 4:00 would be categorized differently and not be taken into account in the consumption estimates for the following days.
I read somewhere (I think here on the forum) that this feature is still in beta.
I have also turned it “on” for myself, but it’s not working correctly (and the display is not right either).
I don’t see any animation yet, and I can’t select that I have connected the charger to the AC-in side.
I think we just need to be patient for a little longer.
Hey Yves,
Can you explain where the option is to activate it in VRM beta?
Hi Bas.
Well, I’ve got an Easee charge robot. I connected a EM24 Ethernet to it. This meter I configured in VRM with the “role” ev charger.
From that point you can monitor the charger.
But, as I mentioned, it’s far from working already the correct way. But maybe in future versions. Let’s hope. It would be a great option to see you’re ev charger directly in the VRM.
Best regards,
Yves
There is additional dropdown menu option for Installation data graphs available for EV Charger - in my case, additional EM24 meter.
