Hi everyone,
When running DESS, with the “target SOC” scheduled to stay flat, it seems that our BMS-reported discharge current is meaningfully higher than the VE.Bus-reported discharge current.
Does anyone have ideas as to why this may be? When the system hits the ESS/DESS “minimum SOC limit”, the difference is much smaller (e.g., 0amps +/- 1 or 2).
This seems to be causing a “self discharge” overnight, while the system is scheduled to keep the SOC flat.
Here’s our system setup:
- 4x Quattro 10k units on firmware v556
- Cerbo GX on firmware 3.60~53
- 60kWh of Discover AES batteries, with a communicating Lynk II CAN-bus BMS (on latest firmwares)
- AC coupled PV on the AC Output side of the Quattros
- No DC loads outside of Quattros (I’ve confirmed the battery heater is not running as well).
We’ve previously posted on a related issue, where it seems the DESS scheduler does not take into account the power draw of the Quattro system itself. However the behavior above makes me wonder if there are multiple factors at play (DESS slowly discharging battery when scheduled to keep target SOC flat)
Thank you!
