I am installing a Cerbo GX into my Victron Li Ion battery system on a catamaran. The distance from two of four chargers is over 40’ due to wire routing limitations. Two of the four chargers can be connected directly with VE.Direct as they are within the 10M length of VE.Direct cables I have. That leaves a VE.Direct port and various USB and CAT5 cable ports on the Cerbo GX to connect to the other two chargers, more than 40’ from the Cerbo GX. I’m mounting the Cerbo GX immediately adjacent to the touch screen which I plan to install at the nav station (did I say the cable needs to be more than 40’ from the Cerbo GX? Groan). Any suggestions?
Related topics
| Topic | Replies | Views | Activity | |
| Maximum length of cable from GX70 to cerbo GX | 1 | 688 | 18 June 2025 | |
| CerboGX & USB Extension Issue | 2 | 293 | 9 February 2025 | |
| Ekrano GX more than 3 VE Direct units 5+m away | 2 | 248 | 10 May 2025 | |
| New install with long distance cables | 6 | 733 | 1 June 2025 | |
| EasySolar-II 48/5000/70-50 MPPT 250/100 GX and Cerbo GX | 3 | 248 | 4 February 2025 |
