I have a backup system (mp2 3000, byd lvs) and after installation the battery charged to 100%. Now it wil not charge and the battery percentage is slowly dropping. The vrm control is on. On the parameters tab on the gx the max charge current displays 0. Discharge is 192A. Can anyone tell me what is my problem?
What kind of lowered SOC do you already have and is your BYD BMS set as a battery monitor?
78% battery monitor = bms byd
Have you possibly received an error message from BYD … for notifications or alarms?
No errors received
How are you charging the battery at the moment?
Grid. The grid is very stable
Try restarting the GX and re-determining the battery …
Is the communication with BYD OK?
BMS - CAN line etc ?
Coms ok. I will try tomorow its far away with very essential loads
Dont worry … But try this tomorrow … The Loads are always resupplied when the GX restarts … the Multi switches to pass-through … it is something other than a FW or assistant upgrade on the Multi
Do you use an ESS System or any Assistants on the Multi ?
and check this again:
https://www.victronenergy.com/live/battery_compatibility:byd_b-box
Update was a drama. 3.52 and now connection lost. Data over 4g.
Having the exact same problem and it started after firmware upgrade during holidays.
No errors anywhere, vrm, BYD BeConnect2, I’ve triple-checked everything, downloaded and uploaded modified configuration with VE.BusSystemConfigurator, even tried without latest ESS-Assistant. Booted batteries and Multi, disconnected-reconnected VE Bus cable,… Running out of ideas. New ones, anyone?
MultiPlus-II 48/3000/35-32, firmware 3.52
Two module BYD LVS
